180mm flips like crazy and crashes on 4s when given throttle! (Newproblem)
Uavskyhigh
Ok so I have a 180mm frame running gemfan 2205 2700kv motors with German maverick 24a esc' s hglteck f3 v4 pro fc with gemfan 4045 3 blades props. Now that being said I had a issue with the front dipping in a previous post, while trying to fix that I hit restore default on betaflight. Now the qaud takes off and hovers but when giving a little punch/throttle the qaud does crazy flips/rolls and crashes on 4s . I bought it used and am having a lot of trouble! Thanks in advance !:)
at what point does the quad go nuts? after a controlled lift of, during a specific manouvour or... ?
I start the qaud on a 4s I start to hover and right when I do a small throttle punch up it flips out like crazy. So any decent to big throttle movement it will flip out I'll try and get a video of it today
Donrabeja
