Acceptable alternatives to DJi for cinematic FPV
Control Freak
I live in a country that is very likely going to be limiting access to DJI products. I would like to build my way up to doing cinematic FPV professionally one day. My question/concern Is if there are other alternative drone setups sufficient for professional cinematic FPV work..for example maybe just using a separate action camera and then using a Walksnail VTX instead of a DJI VTX.
Perhaps even using HD Zero or Analogue in a snap.
Or is having a non DJI VTX unsalvageable for cinematic FPV?
Note: I have my part 107, if it really needs to be known, however note that I say build my way up..including learning more...
I know I just started 2 or 3 years ago with drones so I need to learn much more than what I know however, I just don't want to get stuck on a dead end path (due to legal regulations of my country).
Separate cam is probably how most high end cinematic stuff is done. All in one is only when you need something small and light that can't accomodate a 2nd cam...
The "problem" is that the possibilities/choices are endless.
right now everyone is predicting that BNF drones with dji systems will pass through border cause they’re not labeled as DJi
GCM
