Anyone has the Iflight Cinebee 75HD?
Dronemapper
Hi Guys,
I'm new here so thanks for letting me in
I have him since 3 days but don't like the stock betaflight pid settings, way to sensitive/ aggresive.
Anyone have some advice to thame him like a tinyhawk2 with mockingbird tune?
Look at my pid settings, picture attached
Any help is appreciated
Best regards
Kurt
Reactions: rtkDarling
It's your rate settings that control how aggressively it turns. If you lower your "RC rate" you'll see the numbers on the right (in degrees per second) get lower. The lower the number, the less sensitive the drone is to stick inputs. The next number: "Super Rate" controls how much curve there is in the rates. This has the effect of creating less sensitivity when the stick is close to zero, and increasing sensitivity as the stick deflection increases.
Compare this bird to your tinyhawk and I'll bet your rates are higher. I think the TH was shipping closer to 400 and you're up around 600 right now.
Here's an in depth guide:
Larcas
