I'm newbie on betaflight and really need to ask help from you all expertised guide and help here. I've upgraded JHEF7DUAL to "Betaflight version 1.1.1 (legacy)" in moment, My problems here:
masterset gyro_lowpass2_hz = 325set dyn_notch_range = LOW set dyn_notch_width_percent = 0 set dyn_notch_q = 200 set dyn_notch_min_hz = 90 set dyn_lpf_gyro_min_hz = 260 set dyn_lpf_gyro_max_hz = 650 set motor_pwm_protocol = DSHOT600 set yaw_motors_reversed = ON set small_angle = 180 set pid_process_denom = 1 set osd_units = ###ERROR: CORRUPTED CONFIG: osd_units = 25### set osd_rssi_alarm = 96 set osd_cap_alarm = 742 set osd_alt_alarm = 0 set osd_vbat_pos = 14360 set osd_rssi_pos = 14337 set osd_flymode_pos = 14842 set osd_gps_sats_pos = 14816 set osd_home_dir_pos = 14827 set osd_home_dist_pos = 14828 set osd_flight_dist_pos = 14821 set osd_altitude_pos = 14834 set debug_mode = SMARTAUDIO set vtx_band = 5 set vtx_channel = 1 set vtx_power = 1 set vtx_freq = 5658 Kindly appreciate somebody could help me to fix up on this problem, Thanks a lot. |
