DJI FPV Sensor connection error
dnacho
Hi group,
I am having a problem with my dji fpv drone. It's giving me a sensor connection error with all of the vision sensors. It started out of nowhere and it's the only error im getting, the drone does update correctly
Looks like the entire sensor block might have gotten disconnected.
Hi group,
I have four dji fpv all with the same errors I can't figure out how fix I've replace sensors and cables and it won't alow me to calibrate either help please
Hello, I have a solution to your problem. The problem was that after the accident, a short circuit occurred on the board to which the sensors are connected. In my case, it was the connection connector of the right sensor, which was avoided after the fall and destroyed the capacitor that remained short-circuited. I removed the capacitor and the sensor board was repaired. The core board followed because when there was a short circuit on the sensors, the fuse on the board burned. Since I didn't have such a spare fuse, I used a fiber from a 100mA glass fuse. since it is for a very small distance, the 100mA fuse became a 1A fuse. So I achieved the perfect replacement. The drone works as it should. I hope it helps you and let me know if you succeeded. I know the post is more than a year old, but maybe you still have drones at home. Good luck.DC73D605-7EE2-40A1-BEEA-8A1F2920B5CC.jpeg013ED2B0-ABF0-44D7-8927-7FB785660103.jpeg
Reactions: lapiseine and SWTSU
Hallo, ich habe eine Lösung für dein Problem. Das Problem war, dass nach dem Unfall ein Kurzschluss auf der Platine auftrat, an die die Sensoren angeschlossen sind. In meinem Fall war es der Anschlussstecker des rechten Sensors, der nach dem Sturz vermieden wurde und den Kondensator zerstörte, der kurzgeschlossen blieb. Ich habe den Kondensator entfernt und die Sensorplatine repariert. Die Kernplatine folgte, weil bei einem Kurzschluss an den Sensoren die Sicherung auf der Platine durchbrannte. Da ich keine solche Ersatzsicherung hatte, habe ich eine Faser aus einer 100-mA-Glassicherung verwendet. Da es sich um eine sehr kleine Entfernung handelt, wurde aus der 100-mA-Sicherung eine 1A-Sicherung. So habe ich den perfekten Ersatz erreicht. Die Drohne funktioniert wie sie soll. Ich hoffe, es hilft Ihnen und lassen Sie mich wissen, ob es Ihnen gelungen ist. Ich weiß, der Beitrag ist über ein Jahr alt, aber vielleicht haben Sie noch Drohnen zu Hause. Viel Glück.View attachment 6440View attachment 6441
Bster mann ... ohne dich wäre ich nie auf den fehler gestoßen .... besten daqnk
fpvtune
