DJI Self-Unlocking won't work on Avata FPV drone
jimlips
I've had my DJI Avata FPV drone motion combo for a couple of weeks. I love this thing! It is so much fun for an FPV newbie like me.
The problem I'm having is that what I enter the Flight Controller Serial number on the DJI FLYSAFE Unlock Request website, it does not recognize mine as a valid serial number. I've checked it three times, and I'm positive that it is correct.
I live within 5 miles of a local airport, and often use the DJI Unlock request page to unlock several of my drones so I can fly under 200' in this area.
Has anyone had success registering their Avata on DJI's Unlock page with your controller's serial number?
Thanks in advance!
UPDATE: when I went to register my Avata flight controller serial number today, the DJI website recognized it. I successfully requested to fly in a "height limited" area (where it SHOULD let the aircraft take off). However, the motors will not start on the aircraft. There is a message in the goggles that says something like "can't take off, controlled area".
When I connect my phone to the goggles, it shows "Authorization Zone". When I tap on AZ, it says to follow the instructions to authorize the flight. Not sure what that means, as I have already done that on the website.
I've done this successfully dozens of times with my Mavic Pro Platinum, my Mavic Pro, and my Mini 3 Pro. But the Avata is different. There does not seem to be a way to "import" the authorization into the Avata.
Unless the system is connected to the internet at some point during or after the authorization, it has no way of knowing you've been authorized.
I don't have mine yet, but I suspect you need to have everything turned on and connected, connect the goggles to a smartphone, run DJI Fly, and authorize through Fly.
Never tried it with the FPV... anyone with experience there?
I just had that issue on my maiden flight I wound up, hooking the phone up to my goggles then unlocked through my goggle menu.
williamljackson
