Does i need a 120c battery ?
Rosssiiii
Hello :)
at moment i have 3 x 4s battery ovonic 1550mah 80c.
but i will change engines on my drone and i will put engines that at full throttle will use 43a for single engines.
at moment my battery can give maximum 124 A;
while engines could arrive to use 172a;
so with these battery i can't give 100% throttle exept in rare case.
Now when i flight i generaly never used more the 40% throttle, so i don't know if is good keep these battery or change with more high C ?
is still possible do the refound on amazon !
Hello :)
Go for the 120-C you may not be using high throttle much but every time you ask the battery to produce more current than it is rated for it causes at least a small amount of damage to your battery.
colorsone
