Drone not working :c
Elixius
I bought the Wizzard x220 arf and it arrived today. I built it together and everything was working fine. The FPV system worked, the charger worked and everything was fine. After that I configured the drone in Betaflight and did the motor test and the motors were fine. The reciever also gets a signal from the radio (flysky Fs-i6).
The only problem now is that the motors don´t do anything even if I wack the sticks around on the controller.
Thanks in advance for any ideas/replies!
You need to arm the drone. But first you will need to set up your radio to get the range right for each channel. Also probably will need to calibrate the ESCs.
Hi green,
Where did you get those AWSOME lock nuts for your motors i need 5mm ID nylon lock nuts anodized
Than you Kindly
Keith
prom3th3us
