Emax f3 magnum mini/motor issue
dcwilliams398
Okay.. I'm super perplexed... I have an emax f3 magnum mini tower with aokay 1106 7500kv (2-3s supposedly) motors. I'm using a 550mah 80c battery. When I hit arm the motors IMMEDIATELY go to maximum power and within a split second .. desync. Everything and I mean everything is HOT. The motors the vtx the tower. The battery is absolutely cold. I've looked at every solder joint. I cleaned the boards to ensure there isn't any residual solder. I have smoke stopper. I've checked for continuity. It all looks fine.. I'm at a loss.
Any feedback you can give would be awesome.
It's not desync, what you're experiencing is called anti-taz. A feature of Betaflight that prevents your quad to go screaming around like a Tazmanian Devil. Caused by improper prop orientation, wrong motor rotation or flight controller not installed correctly
