- Joined
- Mar 4, 2021
- Messages
- 272
- Reaction score
- 190
yay, I got new 5" Drone, really happy with it, except one small annoyance - which I would like to remedy.
its got a JHE42 buzzer on it, theres a couple of things I dont really like it.
its large - and given the diatone frame with dji is pretty compact, its placed behind the camera which no ideal.
when you remove the battery it goes off unless you press reset. but the reset button is tiny and fiddly.
also the button is aligned to the connecting cable which is a bit odd (when you consider placement)
I get why the buzzer goes off (in case of battery eject in a crash), but having to find the fiddly button every time I change battery is a bit of a pain.
I guess, I could just remove it - at the moment whilst learning, Im not flying anywhere Im likely to loose it, and I guess as im recording in the googles,
hopefully this would give me an indication of where it went down...
But I guess mid-term, its not a bad idea...
so Im wondering, are there some better options?
something more compact? with a better accessible switch to turn off?
the vifly cable looks better placed, and it looks like its got a better/bigger switch - thoughts?
what would be nice, is perhaps a buzzer where the reset switch is separate, and can be mounted more conviently away from the buzzer.
one thought, I had with the JHE was to desolder the reset switch, and replace it with a wires to another momentary switch.
I know its a small thing, but the JHE is incredibly loud, and so literally painful when it goes off accidentally
