Hello to the team !
I recently got from a friend an Eachine V-tail 210. He crashed it and he never repaired it.
The flight controlled is damaged so i'm searching for a flight controller and a PBD.
I have 4 x Emax lightning-20A ESC
Specs:
Continuous current : 20A
Burst current : 30A(10s)
Li-po battery : 2s-4s
Multishot, Oneshot125
4x Emax RS2205 Motor
Specs:
KV : 2300
Configuration : 12N14P
Idle current(10)@10V(A) : 0.35
No. of Cells(Li-po) : 2~4S
Max. continuous power(W)180S : 135
Internal resistance : 118mΩ
Max. current(180S) : 12A
I was thinking to buy the HAKRC F722 D Mini F7 Flight Controller.
Specification:
Brand: HAKRC
Item Name: F722 DJI 45A Stack
Packing Size: Φ62*33mm
Stack Weight: 25g
Packing Weight: 30g
Flight Controller:
Processor: STM32F722RET6
Gyroscope: MPU6500
BEC: 5V/3A; 9V/2.5A
Storage: 16MB
Input Voltage: 3-6S
Firmware: Betaflight_4.1.0_MATEK722se
Uart serial port: 5
ESC:
Continuous Current: 45A
Maximum Current: 50A (Sustainable 10S)
Assistant Software: BLHeliSuite
Input Voltage: 2S-6S
Drive Signal Support: Dshot150/300/600, Multishot, PWM, Oneshot.
What i can't understand is the current distribution. For example in the one i want to buy it's 45A but does this means it's 45A for each ESC ( 4 x 45A) ? Or it's the total current ( ESC1 + ESC2 + ESC3 + ESC4) ?
I searched on google but i found that both are correct and it got me really confused.
Specs:
Specs:
KV : 2300
Specification:
Brand: HAKRC
Stack Weight: 25g
Packing Weight: 30g
Flight Controller:
Gyroscope: MPU6500
BEC: 5V/3A; 9V/2.5A
Storage: 16MB
Input Voltage: 3-6S
Uart serial port: 5
ESC:
