Flight Controller doesnt connect to Betaflight
chiefkeife
Hi,
So I have a Xilo stax build (both FC and ESC). I flashed my flight controller with the xilo (legacy) firmware but after it successfully flashes it doesn't connect to betaflight. Would anyone know what the problem may be?
Usually that means the FC was flashed with the wrong target for that board. If you have an old CLI dump from before, look to see what target was installed previously.
Okay Im a beginner... so I have no clue what you just told me to do lmao...sorry could you explain in a different way?
ill explain what ive done. so I have downloaded drivers with zadig , then after downloaded drivers with betaflight (xilo legacy) . im going to try the other xilo driver option to see if that works
adax
