Flysky FS-I6 Controller Not "Fully" Binding to FS-IA6
b0baganush
Hello all, I recently got into FPV drones and purchased a kit from a local seller on Facebook Marketplace. Everything seems to be working fine but the Flysky FS-i6 controller will not "fully" bind to the FS-iA6 receiver. I have read multiple forum posts and watched the videos out there but nothing seems to be working. Below are the steps that I am taking:
1. Place bind key on the top B/VCC labeled pins on the FS-iA6
2. Place 5v power to the channel 3 pins and turn on
2a. Receive fast flashing red LED on the FS-iA6
3. Press and hold bind key and turn on FS-i6 contoller
4. Screen shows RX Binding / RX Bind OK
4a. FS-iA6 LED starts slow blinking
5. Remove bind key from the B/VCC pins on the FS-iA6
At this point everything says that the FS-iA6 will have a solid LED showing and that there will be RX data showing up on the screen of the FS-i6 controller but nothing happens. The FS-iA6 just keeps showing the slow blinking LED and not RX data shows up on the controller screen. Anyone have any idea what is going on here? Thanks for your help.
Did you ever solve this issue, mine is behaving the same.
When the receiver is powered on (with slowly blinking), go to System Setup >> RX Setup >> Failsafe >> All channels >> Yes, to reset all channels to their factory default state. Then the receiver LED will stay on static. Turn off and on the receiver again, and it will put the LED to fast blinking (ready to bind) again.
peek.shwd
