I bought a Eachine Wizard 220 and it came with the fly sky FS-i6 transmitter and Flysky FS-A8S receiver single antenna. I set it up on Betaflight. Took out to fly and it would lose range less then 50 feet away or if I stayed within 50 feet of myself but went up 30 feet it would lose signal and failsafe and drop out of the sky. So I changed receiver to Flysky X6B i-BUS 2.4GHz 6CH Dual Antenna Receiver for AFHDS i6s i6 i6x Transmitter.
This helped the range but only slightly to maybe 300 feet away??? It seems to me that these quads I see on you tube are able to run several football fields away and they are flying through buildings and around obstacles not problem. Also I looked up the fly sky range on the net and range tests show 1.2 to 2.5 km? So I recently bought an Eachine Trashcan and the range on this is even worse, it loses signal just 20 feet away and failsafes hits the ground???? So what gives, I check the antennas connection and both were fine. I had the original receiver in the wizard and changed out for the X6B not much improvement and now I have the trashcan and its range is worse. So is my Fly Sky transmitter the prob? Or is it defective? Should I bother fixing it or just replace it with a Taranis??? Any help would be greatly appreciated. I would upgrade to a teranis Xd7 or 9 as long as that would solve the problem. Not much fun trying to fly within such a small space and every time it failsafes it cost a lot to fix???
