Hawk pro Won’t sit still
Gotrdone
My emax hawk pro won’t hover anymore it wants to go backwards and to the right a little. Can I fix that in beta flight?
If you are flying in an auto leveling mode, your accelerometer is probably out of whack on what's level, plug into BF and put it flat on a level surface and do a accelerometer calibration that's on the first tab I think. It isn't usually perfect but gets you back close enough, if you want to fine tune it you can watch Joshua Bardwell's video on BF stick commands.
Reactions: tevek
Thank you I did the calibration but still the same I’ll watch the video
Maybe post a short video so we can see what is happening in flight, if a calibration didn't fix it then it could be a bad gyro/accelerometer, you may want to try getting a CLI dump and re-flashing the FC with the same rev since occasionally the BF can get whacky too.
Reactions: Gotrdone
This is what I got. And why is motor 4 slower than the others. Could that be the problem
