Hello from Westren Masschusetts
Welcome to the forum 👍👍
Thanks doug, I also am a member mavic forum can I use the same user name, if so how do I edit it?
Is Dirk and you could have your user’s name when you joined here
if it hadn’t been used before here. Will let @clackey look at it.
I am confused ,I just want to change my user name on FPV FORUM FROM Doug to Oman the one I use on MAVIC FORUM is that possible , if so how do I do that?
Thanks much oman
PS: I also want to change the location. I made a mistake. I want to change it from Westren to Western. Is that possible? Thank u for your help.Doug
Thanks much oman
As I said when the Adimn @clackey sees this hae can help you. I can’t.
Welcome to the forum! :)
erix fpv
