D
Deleted member 3641
Guest
I have a 85mm whoop build with a "HappyModel CrazyBee X V2.2 F4 1-2S AIO Whoop Flight Controller". I have been flying it on 1S batteries with no problem. There is a PH2.0 power connector and I have some 2S batteries with the same connector. When I try to use the 2S battery, the second I arm it, its heading for the skies with "0" throttle...
I am using the default PIDs that came with the FC.
I noticed something in the battery section in Betaflight. Does the min and max volt setting have anything to do with it?
