Funnily enough I’ve just ordered a replacement nano receiver for my DC3. Low RF warnings and failsafes galore. No idea why it went from being ok to just lunching itself but I guess it’s just part of this hobby..... I see a lot of people are running AXii antennas but not sure if they are that much better than stock, unless you’re doing bandos and the like.Sorta boring flight but was able to test my replacement Nano receiver. This one had no receiver warnings when DJI goggles had 1 bar of reception. Last receiver was obviously faulty. Next I need to beef up DJI range with AXII HD antennas.
All my quads are running on 915mhz, dynamic turned off and I’ve tried varying power options, latest Agent update and this one quad refuses to play nicely. As for setting up LQ, I used this tutorial to set mine up.I got the replacement receiver through TBS. The first problem I had was that the frequency was wrong. That fixed some of the problems but I still had receiver warnings. This new Nano seems a lot better although my LQ display wasn't working for this flight. Will be able to see some numbers next time.
I got the combo AXII HD which should give me much better range when I am looking directly at the quad (at least per Nurk's review).
Yeah, I also used Oscar's LQ tutorial. I realized when I got to the field that I had forgotten to do the dst channel setup for the new receiver. So my LQ value was stuck at 49. At first it freaked me out but once I realized the numbers weren't changing I knew it wasn't connected. I am going to try to get back out there today and will have real numbers to report.All my quads are running on 915mhz, dynamic turned off and I’ve tried varying power options, latest Agent update and this one quad refuses to play nicely. As for setting up LQ, I used this tutorial to set mine up.
LQ and RSSI Explained for ExpressLRS and Crossfire - Oscar Liang
Learn about the difference between LQ and RSSI in ExpressLRS, how to use them to monitor your FPV drone's signal strength and determine maximum range.oscarliang.com
