Issue taking off with Crosssfire Nano- Green Hornet
RSILVA777
I have a green hornet,6s, with Crossfire Nano. According to Betaflight, I have movement, and all settings appear to be correct. The Tango 2, arm button is set at (SD) is working.Flight mode is set to SB. Once I power on the quad, the solid green light on the quad is constant green.
I'm not sure the solid green light has anything to do with your issue, and the exact issue isn't clear from your post or title, can you be a bit more specific on what the quad is not doing? Is it failing to arm, if so can you show a screenshot of BFC Receiver tab showing SD active for arming? We can try to help if you elaborate more on the issue.
happypapaya
