Lost newbie
JWFSells
I didn't realize that the Hawk Pro was PNP until I had already opened it. I have been all over YouTube and various forums trying to figure everything out. I have the Taranis QX7 access w/ the R9M. I've been hung up on trying to figure out what reciever I need that will work with the Taranis and the Hawk Pro, if I need a module and if so witch one... Any help or suggestions at all would be greatly appreciated.
-I'll include pictures of what I have to hopefully make it easier to be able to tell me anything about what I need and need to do
. IMG_20220101_135351_268.jpgIMG_20220101_135444_306.jpgIMG_20220101_135504_140.jpgIMG_20220101_143708_918.jpgIMG_20220101_144333_084~2.jpg
If you are going to use the R9M module, you need a R9 reciever, like here:Amazon.com: FrSky Access 900MHz Long Range R9 Mini-OTA Receiver : Toys & Games
Or... you could flash your R9M with Expresslrs and run elrs 900 mhz reciever like here: https://www.amazon.com/Quadcopter-Compatible-Transmitter-Radiomaster-ExpressLRS/dp/B0912SXM6M?th=1
Or you can use your radio without the module and you then need a 2.4 ghz FrSky ACCESS reciever like: Amazon.com: FrSky XM Plus Mini Receiver up to 16CH 1.6g Full Range fit for Micro Drone XM : Toys & Games
Reactions: Fast and Curious
Senkq
