So i have a mobula 6 and i have had it for quite a while now. i had to replace the board once after it breaking but after a while with the new replacement board it seems to be able to fly for a bit until i punch the throttle and then it disarms or failsafes.
The batteries are definitely not the problem i have 10 and i've tried all of them ive also made sure the motors are spinning the right way and the props are on properly. i have also flashed the firmware again in betaflight and reset it to its stock form.
Do you have and idea what the problem could be.
I have a flysky fsi6 which is working fine.
i have the 2500kv version and the frame is in good condition
Sometimes once i've armed it and i add any throttle it dissarms and rearms and then sometimes it completely dissconnects from the transmitter.
Thank you.
Thank you.
