I really loved the idea behind the motion controller. Bu there are things that I wished or hope to see the motion controller supporting, such as:
1. A way to fly backwards. Unfortunately there are no custom buttons to switch direction, but one way to do it is either to hold down the mode button or alternatively hold down the tilt button (since it cannot be used while flying).
2. A way to rotate around a pivot point. Again this would require holding a button to lock the dot and make the gyro movements in relation to the dot.
3. A manual mode where the pitch, yaw, and tilt would be continuous only after exceeding a certain angle/threshold in each direction (outside the box), while being in angle mode otherwise (inside the box). The trigger of course will control the throttle. It will be difficult, and there will be a learning curve, but it will also enable flying backwards.
4. At least one more custom button in a next version, or maybe an add-on for the other hand which can be connected to the usb port allowing extra features or maneuverability
