Motor direction
Davey
Nj
Hello. I got 4 brother hobby motors . They all have the same diredtoin threadd on top. Will my blade come loose when flying. Thanks
Use nylock nuts and it should be fine. Also, you should be able to hear the prop slipping when the nut becomes loose if it does.
Just dont use those cone shaped ones, or at least not without a lock washer under it. I have a few different color bags of (3ea), and some leftover drone parts due to thinking it would hold. GO NYLOCK.
