Motor wire change out
4th_Dimension
Good evening guys,
So I'm building my Tyro79 and they used cheap plastic wires for the motors. It's maybe 22-24 gauge wires. I am thinking about changing these wires for the motors out with 20 gauge silicone wire. Would this be ok or will there be a problem because of the size difference?
Thank you,
Brian
They will be ok, but that is a lot of work for no real difference except a little more supple wire.
Thank you sir fro answering back.
Yes I see this now, so I think I will pass on doing this. Unless I maybe can splice the wires. Cut the cheap plastic ones as short as I can and then splice it there and run the silicone wire to the ESC. What do you think?
colorsone
