NEED HELP
SmoothRiderz
Just got a new Dji Fpv Drone and during launch it wanted to tilt backwards, so i added more throttle and forward movement (right stick) and it still went backwards i ended up shredding the rear two blades and i have no clue why it did that, i calibrated everything and the props were on properly to the corresponding colors can someone explain why this happened?
It was also in normal mode when i tried launching (btw the drone didnt even get off the ground it just tilted backwards right onto the blades)
j-drone
