One of my motors is getting hot left rear.
I thought it was damaged because during the tests in Betaflight you can hear rattle/scratching when you run above the speed 1000.
I replaced the engine with a new one and immediately after replacement I started the Betaflight and the new engine behaves the same also it gets hot quickly.
My quad is GEPRC MARK5 HD 6S with GEPRC SPEEDX2 2107.5 1960KV.
New motor is "GEPRC SPEEDX2 2107.5 1960KV blue"
which parameters are the same except for the color but I assume the colors are irrelevant beyond the aesthetic matter.
Does my problem mean that I have a damaged something?
Well, I talked to a person who knows is a service technician and it turns out that my ESC is for replacement because after the crash I did not reduce the speed and the ESC system was damaged.
So another question, can you advise me a good ESC replacement for this model (GEPRC MARK5 HD 6S) which has "SPAN G50A BLHeli_32 4IN1 50A 4-6S".
