Props dont spin!
jonathannord
After i calibrated the mid and endpoints on my taranis qx7 the props wont spin when i arm the drone. Anyone know how to fix this. The props have spun before.
WITH PROPS OFF test to see if you can spin them in the Motors tab in BF configurator, if so, check that the Motor Stop is not checked in the Configuration tab, and that the Throttle is at 1000 in the Receiver tab. Lastly check for any Disarm Codes on the right hand side of the Setup tab or from the CLI tab with the "status" command (look at the last line of the output).
CLI and MSP are normal because the USB is plugged into the quad, the THROTTLE though is telling you that the throttle value is too high. Either your Throttle is not at 1000 and/or you have the wrong channel map selected is likely causing this. So what is the value of Throttle when the throttle stick is all the way down in the Receiver tab? Got a pic of your Receiver tab?
When the stick is all the way down the throttle is at 1000.
ebchopra
