So end of the day and I'm going to fly, get my stuff and a couple batteries and out the back door I go. Normally my first flight I make my rounds around my property, wood, fields, ponds, whatever I kind of cruise around at altitude normally in that 150 foot range so I'm above everything and check things out. Well I'm getting better at this guy so from that 150 ish loot level I go screaming down into my back field, get to about 65 feet and BANG I lose ALL signal! I get the warning in my goggles of a "critical failure" RTH or something like that and my goggles go blank! What the heck??? At first I get nothing at all in the goggles, then it comes back for a moment says something about hover and goes blank again. Now the screen is not really blank but there are no values listed anywhere all just lines. So I remember I've been flying IN the woods and have my RTH set to hover so I try to change that... nope, not while it is in RTH mode I cant even access "advanced safety ". I click on "find my drone" and it brings up the last 10-15 seconds of video I was shooting and shows me right where it should be sitting.. hovering! Now I'm kind of in that panic mode at this point and I know the battery is going to be getting low and I hope it truly is sitting there! Dang... I grab my stuff and start the jog out to where it should be because without any signal I have no picture!!! No real clue if its sitting there or anything!! Holy incriminating evidence Batman, YES I am flying BVLOS!! Get over it will ya! Its all on my property! So I get maybe 3/4 of the way out there and I regain signa!! Woopie!! I cancel RTH , reset the RTH to go to home point and almost immediately it goes into Battery Low RTH! Up up and away it goes and off to home, I wait till it gets close to its landing spot I shut off RTH and land it in the grass in my back yard!! YAY!!
So I throw the next battery in it and go to do the exact same thing but this time knowing what might happen, and having RTH set to actually come home if it does. Now this is a field I fly in all the time BUT from a different location, I normally fly from my sniper tower out in the same field, straight line and VLOS to that end of the field. Anyway, I do the same thing, go screaming down into the field from altitude and once again lose all signal (make mental note of such) this time it climbs to 132 ft altitude for RTH at which time it gets signal as it climbs above the tree line! I thought I would just let it run its course and RTH which it did with no problem.
So I'm guessing if it loses all signal with the remote and goggles the birds GPS is what brings it to the home point.. good lesson learned!
