SpeedyBee F405 AIO 40A cannot detect the magnetometer of GEP-M1I
Ekaterina
Canada
Hi, I have a trouble to figure out how to use the Mag.
SpeedyBee F405 AIO 40A Bluejay flight controler cannot detect the magnetometer of GEP-M10I (IST8310 included model).
reference sites are:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://geprc.com/wp-content/uploads/2023/08/The-solution-for-GEP-M8Q-M10-DQ-and-other-GPS-module-magnetometers-and-barometers-not-working.pdf
Current condition are;
- GPS fuction is working well.
- BARO icon from the FC, and GPS icon from GEP-M10I are ON, but Mag icon is OFF in Beta flight config UI.
- I soldered 6 cables from the GPS to the FC properly with triple checks, with a tester. (and of course, GPS's SDA should go to FC's SDA, and GPS's SCL should go to FC's SCL. I hope their instuction print would not be wrong...)
- I flushed my FC as GEPRC's PDF's instruciton, adding other options > Magnetometers, but I skipped "Custom Defines BARO_MS5611 BARO_DPS310" because of getting errors. However, my FC already has Baro, and M10I does not have Baro, I should not need this custom defines
- I changed the device numbers couple of times as GEPRC's PDF's instruciton, but did not work.
If you find a soulution how to use this GEPRC's Mag, or you confirmed that other GPS products' Mag is working with the FC, please let me know thanks!
