Taranis QX7 Roll issue
Leeroy J
My controller and quad is working perfectly apart from the roll. As you can see in the video there is a huge slow smoothing to the roll which makes it unusable. As well as the stick not coming back to center quickly.
I have done my best to look into Betaflight and the controller settings but cant seem to find the problem.
I have updated my Flight Controller Firmware and re-bound the controller.
Any ideas what this could be???
Check out the video below.
This is happening with mine too. not sure what it is but i'm taking it apart tomorrow and will post with some updates.
The original video shows a faulty gimbal, probably a broken wire or the pot itself being dead.
I also believe this is a failed or failing gimbal, but what you could try is to re-calibrate the radio to see if it helps.
Rcambbatrans
