Good day fellow pilots. I have the same problem right now. Yesterday I received my Geprc Mark 5 with tbs nano RX and TBS Tango 2 Pro. When I was binding first time everything looked normal and it bound. Then I connected my drone to betaflight and Transmitter was working just fine. I set up arm, beeper and modes to the buttons on my receiver. When I tested the drone, motors were spinning but not with the same rpm. I checked on betaflight and two of them were spinning a lot faster. So that was my first problem. Second problem was that when i pushed throttle stick up just a little bit, motors immediately started spinning almost to the max. And when I pushed throttle all the way down motors were is spinning at max rpm. Then I tried fixing these two problems and with that came third one.
Now when i move throttles it wont show anything on betaflight. TBS nano rx has solid green light, on Tango 2 it shows signal strength and also green light, when i power off my drone it says telemetry lost on my Tango 2. So that means they are bound. I have been searching on internet for the past two days and i still haven't found the solution. I updated my Tango 2 and nano rx, re-bound them multiple times but its still the same. No input on betaflight. Its like my controller wasn't even connected. I feel like drones hate me since i had a lot of problems with my previous one as well.
If any of you guys would time some time and help me, i would be very grateful.
Thank you,
Jake
Thank you,
Jake
