Doing nothing usually means no power but your wiring looks correct to me?? I'd check to see that there are actually 5v on the pad.
TBS nano receivers do not need the bind boot pressed when powering up, at least not the very first time. They are designed to enter bind mode automatically and update through the transmitter module. Again, no lights of any color would mean no power. If there's 5v on the pad it would point to a bad RX to me.
If there is power, holding the button while powering on, then releasing and holding it again until the flashing green light changes rate will do a factory reset and it should enter bind mode next time its powered on... all else working of course.
