Tiny fish stack esc problems...
baevans11
Hey again! So I found some info from TBS on how to wire up the vtx and camera and I found some diagrams on the esc motor order. I have the tiny fish stack all wired up but only motor 2 spins and it is sporadic. I went into config and tried dshot 300 & 600. I also went into blheli to flash the escs and it says 1 & 4 are unknown or have been erased. I was able to flash the other 2 escs with no trouble but when I try to manually pick the same target that worked for those escs to flash the unknown ones it says flash writing block failed. When I go into the motors tab none of the motors spin except 2 and like I said it just randomly twitches. I'd appreciate any help. I checked all of the solder points on the esc and they are fine.
