Tyro99 w/ Flysky FS-i6 + FS-iA6B RX works but only in Betaflight Help!
Alister Mac
This is my first build so EVERYTHING is being learned on the "fly" HA
Thanks to this Forum I was able to figure out that I needed to jumper the FC ibus pad and set my TX to PPM=ON. This was exciting because I now have control of my drone. At least according to the Receiver tab in Betaflight. I also have motor control via Betaflight. However, once I disconnect from Betaflight and attempt to arm and fly... i get nothing! The TX and RX bind but that's all. It won't even arm.
What am I missing? Something simple I hope.
Make sure to calibrate your accelerometers while quad is on a completely level surface. Check that your arm mode is responding correctly in Betaflight (there is an icon at the top of the window that indicates quad is armed). Make sure your throttle is all the way down (below threshold level to arm). Don't forget to save & reboot FC. Check settings again after reboot. Happy flying!
Reactions: Alister Mac
Larcas
