So I set up my new Jumper T12 Pro and went out to fly today. Several times my qwads had a sudden yaw adjustment when I was flying along, hovering or inverted. I recalibrated the Tx but no difference. It happened without warning and with no discernable pattern. I couldn't duplicate the problem nor was it happening for the same amount of time. Sometimes just a quick blip turning 20 degrees some times 5-6 turns in a row before recovering. It was definitely to the left but might have been to the right as well. It was hard to keep track, it was very disorienting. I switched back an forth between two different qwads to make sure it wasn't just a FC issue.
First real flights with this controller. I did some test hovers after binding my qwads but that was only inside.
Any ideas?
Any ideas?
