Vusion 250 v2 cli dump
Shawn
Hello! Does anyone have a vusion 250 that would be able to post the factory settings in a cli dump? I flashed the FC and completely forgot to back up a file lol.
hmmm, I have a Vusion 250 but its about 3 1/2 years old. I never knew you could get cli or even reload it so maybe its a different model?
there wasnt much extreme about it other than it was pretty schechy to fly lol
There’s a port toward the right rear near motor 1 and there’s a boot load button under the top cover. It does work with betaflight so long as you DONT FLASH IT ??‍♂️
Still have a brand new V1 BNF Race still in the box. Unfortunately the V1. Quads did not give easy access to the MSP port, I don’t know what rev of BF it’s running, but I can confirm they are running SPRacingF3 Hardware, but what BF Firmware it is running I don’t know. Let me see what I can find for a V2 dump.
I appreciate it! I read another thread you helped a guy with. I think he did nearly the same thing.
Looked into it and I think you will need to put in a support request with Horizon Hobby's on their website.
Ask them for a hex file of the betaflight,, or whatever revision of the standard betaflight SPF3 target it may be running, and get them to get a dump file off of one for you.
Reactions: Futuramille
There is a couple dozen very specific configuration items that need to be looked at, it sure would help to have a dump from this quad, rule of thumb is to always check that the FC is running by plugging up and getting a cli dump, as you can see, the information is critical. Rise could be running a self compiled version from the development files, or they could be using off the shelf rev X of the SPF3 target, without a full dump it is hard to say. The best answer I can find, is contact Horizon support and ask for a cli dump off of one of the V2's they have there at the shop and lets go from there.
But
If the motors all spin
If the FC orientation is correct
If the ESC protocol is right
The ESC's may need to be calibrated
If the betaflight endpoints and midpoints are properly set and reached
If the motor location is correct
If the directions of rotation are correct for either props in or props out (likely props in rotation)
And the props are on right...
They will fly, even if they don't do it well.
Donrabeja
