What's my bullet esc problem
Looknow
Eachine racer with 3306 emax motors and 20 amp escs, rev 6, regular pdb, everything is getting hot , catching esc on fire within minutes. Fly' s great though pods good.clesnflight and blheli suite. Any guess's
Hi LK,
As a noob,
It sounds like the ESC'S are to small for the motors ...or did you mean 2306?
Have you removed any filters from the bird? (Clean flight).
Look on YouTube describing your problem. Also look up cleanflight setup.
Keith
Two possibilities come to mind. You may have a small short, or perhaps your motor screws are too long and touching the windings.
First, check the screw length. Then check for a short using the ohm-meter setting of a multimeter. You should get high resistance between each combination of Vbat, ground and chassis.
