Hi all,
My quad is slightly turning left so I connected it to betaflight to look into this.
I have calibrated my radio which is Taranis X9D plus, and I set output points so all the values show at 1500 in betaflight.
It's all looking good except Yaw as the value is 1500 and 2 seconds later it's changing to 1481 by itself. It's pretty much jumping between these numbers.
So I opened the radio and checked all the tension screws but no luck. Then I upgraded the gimbal for frysky M9-R and calibrated the radio all over again.
Yaw's value is still changing by itself so I am about to give up...
Does anyone have any idea what may cause a problem? Any help is much appreciated
