All parts are in need advice on wiring
  • Thread starter Thread starter Deleted member 3641
  • Start date Start date
@HighTechPauper Any ideas why I am not getting the sensors?
It could be that it doesn't have any sensors to offer. Are you sure Telemetry is enabled in the Config tab? I have never run FPort so I am not 100% sure of the configuration for it. My guess is that there are more sensors and it is a config issue.
What firmware rev did yo load on the R-XSR?
Can you post some pics of the config page and the CLI setting associated with inversion etc?
X-RSR Firmware:
RXSR-FPORT_FCC_ACCST_191128
JB mentioned in his video that if you are not getting stick response in BF to try changing these two values. This is the combo that got the sticks responding.
serialrx_inverted = OFF
Allowed values: OFF, ON
serialrx_halfduplex = ON
Default value: OFF
Here is the full CLI as I am not sure what parts you need.
# get
gyro_hardware_lpf = NORMAL
Allowed values: NORMAL, 1KHZ_SAMPLING, EXPERIMENTAL
gyro_sync_denom = 1
Allowed range: 1 - 32
gyro_lowpass_type = PT1
Allowed values: PT1, BIQUAD
gyro_lowpass_hz = 200
Allowed range: 0 - 4000
gyro_lowpass2_type = PT1
gyro_lowpass2_hz = 250
gyro_notch1_hz = 0
gyro_notch1_cutoff = 0
gyro_notch2_hz = 0
gyro_notch2_cutoff = 0
gyro_calib_duration = 125
Allowed range: 50 - 3000
gyro_calib_noise_limit = 48
Allowed range: 0 - 200
gyro_offset_yaw = 0
Allowed range: -1000 - 1000
gyro_overflow_detect = ALL
Allowed values: OFF, YAW, ALL
yaw_spin_recovery = ON
yaw_spin_threshold = 1950
Allowed range: 500 - 1950
gyro_to_use = FIRST
Allowed values: FIRST, SECOND, BOTH
dyn_notch_range = MEDIUM
Allowed values: HIGH, MEDIUM, LOW, AUTO
dyn_notch_width_percent = 8
dyn_notch_q = 120
Allowed range: 1 - 1000
dyn_notch_min_hz = 150
Allowed range: 60 - 1000
dyn_lpf_gyro_min_hz = 200
Allowed range: 0 - 1000
dyn_lpf_gyro_max_hz = 500
gyro_filter_debug_axis = ROLL
Allowed values: ROLL, PITCH, YAW
acc_hardware = AUTO
Allowed values: AUTO, NONE, ADXL345, MPU6050, MMA8452, BMA280, LSM303DLHC, MPU6000, MPU6500, MPU9250, ICM20601, ICM20602, ICM20608G, ICM20649, ICM20689, BMI160, FAKE
acc_lpf_hz = 10
acc_trim_pitch = 0
Allowed range: -300 - 300
acc_trim_roll = 0
acc_calibration = -93,-1,-322
Array length: 3
Default value: 0,0,0
align_mag = DEFAULT
Allowed values: DEFAULT, CW0, CW90, CW180, CW270, CW0FLIP, CW90FLIP, CW180FLIP, CW270FLIP, CUSTOM
mag_align_roll = 0
Allowed range: -3600 - 3600
mag_align_pitch = 0
mag_align_yaw = 0
mag_bustype = I2C
Allowed values: NONE, I2C, SPI, SLAVE, GYROAUTO
mag_i2c_device = 1
Allowed range: 0 - 3
mag_i2c_address = 0
Allowed range: 0 - 119
mag_spi_device = 0
mag_hardware = NONE
Allowed values: AUTO, NONE, HMC5883, AK8975, AK8963, QMC5883, LIS3MDL
mag_declination = 0
Allowed range: -18000 - 18000
mag_calibration = 0,0,0
Array length: 3
baro_bustype = I2C
baro_spi_device = 0
Allowed range: 0 - 5
baro_i2c_device = 1
baro_i2c_address = 0
baro_hardware = NONE
Allowed values: AUTO, NONE, BMP085, MS5611, BMP280, LPS, QMP6988, BMP388
baro_tab_size = 21
Allowed range: 0 - 48
baro_noise_lpf = 600
baro_cf_vel = 985
mid_rc = 1500
Allowed range: 1200 - 1700
min_check = 1050
Allowed range: 750 - 2250
max_check = 1900
rssi_channel = 0
Allowed range: 0 - 18
rssi_src_frame_errors = OFF
rssi_scale = 100
Allowed range: 1 - 255
rssi_offset = 0
Allowed range: -100 - 100
rssi_invert = OFF
rssi_src_frame_lpf_period = 30
Allowed range: 0 - 255
rc_interp = AUTO
Allowed values: OFF, PRESET, AUTO, MANUAL
rc_interp_ch = RPYT
Allowed values: RP, RPY, RPYT, T, RPT
rc_interp_int = 19
Allowed range: 1 - 50
rc_smoothing_type = FILTER
Allowed values: INTERPOLATION, FILTER
rc_smoothing_input_hz = 0
rc_smoothing_derivative_hz = 0
rc_smoothing_debug_axis = ROLL
Allowed values: ROLL, PITCH, YAW, THROTTLE
rc_smoothing_input_type = BIQUAD
rc_smoothing_derivative_type = BIQUAD
Allowed values: OFF, PT1, BIQUAD
rc_smoothing_auto_smoothness = 10
Allowed range: 0 - 50
fpv_mix_degrees = 0
Allowed range: 0 - 90
max_aux_channels = 14
Allowed range: 0 - 14
serialrx_provider = FPORT
Allowed values: SPEK1024, SPEK2048, SBUS, SUMD, SUMH, XB-B, XB-B-RJ01, IBUS, JETIEXBUS, CRSF, SRXL, CUSTOM, FPORT, SRXL2
Default value: SBUS
spektrum_sat_bind = 0
spektrum_sat_bind_autoreset = ON
srxl2_unit_id = 1
Allowed range: 0 - 15
srxl2_baud_fast = ON
sbus_baud_fast = OFF
airmode_start_throttle_percent = 25
rx_min_usec = 885
rx_max_usec = 2115
Default value: OFF
rx_spi_protocol = V202_250K
Allowed values: V202_250K, V202_1M, SYMA_X, SYMA_X5C, CX10, CX10A, H8_3D, INAV, FRSKY_D, FRSKY_X, FLYSKY, FLYSKY_2A, KN, SFHSS, SPEKTRUM, FRSKY_X_LBT
rx_spi_bus = 0
rx_spi_led_inversion = OFF
adc_device = 1
adc_vrefint_calibration = 0
Allowed range: 0 - 2000
adc_tempsensor_calibration30 = 0
adc_tempsensor_calibration110 = 0
input_filtering_mode = OFF
blackbox_p_ratio = 32
Allowed range: 0 - 32767
blackbox_device = SERIAL
Allowed values: NONE, SPIFLASH, SDCARD, SERIAL
blackbox_record_acc = ON
blackbox_mode = NORMAL
Allowed values: NORMAL, MOTOR_TEST, ALWAYS
min_throttle = 1070
max_throttle = 2000
min_command = 1000
dshot_idle_value = 200
Default value: 550
dshot_burst = AUTO
Allowed values: OFF, ON, AUTO
dshot_bidir = OFF
dshot_bitbang = OFF
dshot_bitbang_timer = AUTO
Allowed values: AUTO, TIM1, TIM8
use_unsynced_pwm = OFF
motor_pwm_protocol = DSHOT600
Allowed values: OFF, ONESHOT125, ONESHOT42, MULTISHOT, BRUSHED, DSHOT150, DSHOT300, DSHOT600, PROSHOT1000
motor_pwm_rate = 480
Allowed range: 200 - 32000
motor_pwm_inversion = OFF
motor_poles = 14
Allowed range: 4 - 255
thr_corr_value = 0
Allowed range: 0 - 150
thr_corr_angle = 800
Allowed range: 1 - 900
failsafe_delay = 4
failsafe_off_delay = 10
failsafe_throttle = 1000
failsafe_switch_mode = STAGE1
Allowed values: STAGE1, KILL, STAGE2
failsafe_throttle_low_delay = 100
Allowed range: 0 - 300
failsafe_procedure = DROP
Allowed values: AUTO-LAND, DROP, GPS-RESCUE
failsafe_recovery_delay = 20
failsafe_stick_threshold = 30
align_board_roll = 0
Allowed range: -180 - 360
align_board_pitch = 0
align_board_yaw = 0
gimbal_mode = NORMAL
Allowed values: NORMAL, MIXTILT
bat_capacity = 0
Allowed range: 0 - 20000
vbat_max_cell_voltage = 430
Allowed range: 100 - 500
vbat_full_cell_voltage = 410
vbat_min_cell_voltage = 330
vbat_warning_cell_voltage = 350
vbat_hysteresis = 1
Allowed range: 0 - 250
current_meter = ADC
Allowed values: NONE, ADC, VIRTUAL, ESC, MSP
battery_meter = ADC
Allowed values: NONE, ADC, ESC
vbat_detect_cell_voltage = 300
use_vbat_alerts = ON
use_cbat_alerts = OFF
cbat_alert_percent = 10
vbat_cutoff_percent = 100
force_battery_cell_count = 0
Allowed range: 0 - 24
vbat_lpf_period = 30
ibat_lpf_period = 10
vbat_duration_for_warning = 0
vbat_duration_for_critical = 0
vbat_scale = 110
vbat_divider = 10
vbat_multiplier = 1
ibata_scale = 210
Allowed range: -16000 - 16000
Default value: 400
ibata_offset = 0
Allowed range: -32000 - 32000
ibatv_scale = 0
ibatv_offset = 0
Allowed range: 0 - 16000
beeper_inversion = ON
beeper_od = OFF
beeper_frequency = 0
beeper_dshot_beacon_tone = 2
Default value: 1
yaw_motors_reversed = ON
Default value: OFF
crashflip_motor_percent = 0
3d_deadband_low = 1406
Allowed range: 750 - 1500
3d_deadband_high = 1514
Allowed range: 1500 - 2250
3d_neutral = 1460
3d_deadband_throttle = 50
3d_limit_low = 1000
3d_limit_high = 2000
3d_switched_mode = OFF
servo_center_pulse = 1500
servo_pwm_rate = 50
Allowed range: 50 - 498
servo_lowpass_hz = 0
tri_unarmed_servo = ON
channel_forwarding_start = 4
Allowed range: 4 - 18
rateprofile_name = -
rateprofile 0
thr_mid = 50
rateprofile 0
thr_expo = 0
rateprofile 0
rates_type = BETAFLIGHT
rateprofile 0
Allowed values: BETAFLIGHT, RACEFLIGHT, KISS
roll_rc_rate = 100
rateprofile 0
pitch_rc_rate = 100
rateprofile 0
yaw_rc_rate = 100
rateprofile 0
roll_expo = 0
rateprofile 0
pitch_expo = 0
rateprofile 0
yaw_expo = 0
rateprofile 0
roll_srate = 70
rateprofile 0
pitch_srate = 70
rateprofile 0
yaw_srate = 70
rateprofile 0
tpa_rate = 65
rateprofile 0
tpa_breakpoint = 1250
rateprofile 0
tpa_mode = D
rateprofile 0
Allowed values: PD, D
throttle_limit_type = OFF
rateprofile 0
Allowed values: OFF, SCALE, CLIP
throttle_limit_percent = 100
rateprofile 0
Allowed range: 25 - 100
roll_rate_limit = 1998
rateprofile 0
Allowed range: 200 - 1998
pitch_rate_limit = 1998
rateprofile 0
yaw_rate_limit = 1998
rateprofile 0
reboot_character = 82
Allowed range: 48 - 126
serial_update_rate_hz = 100
Allowed range: 100 - 2000
imu_dcm_kp = 2500
Allowed range: 0 - 32000
imu_dcm_ki = 0
small_angle = 25
Allowed range: 0 - 180
auto_disarm_delay = 5
Allowed range: 0 - 60
gyro_cal_on_first_arm = OFF
gps_provider = NMEA
Allowed values: NMEA, UBLOX, MSP
gps_sbas_mode = AUTO
Allowed values: AUTO, EGNOS, WAAS, MSAS, GAGAN
gps_auto_config = ON
gps_auto_baud = OFF
gps_ublox_use_galileo = OFF
gps_set_home_point_once = OFF
gps_use_3d_speed = OFF
gps_rescue_angle = 32
gps_rescue_initial_alt = 50
Allowed range: 20 - 100
gps_rescue_descent_dist = 200
Allowed range: 30 - 500
gps_rescue_landing_alt = 5
Allowed range: 3 - 10
gps_rescue_landing_dist = 10
Allowed range: 5 - 15
gps_rescue_ground_speed = 2000
Allowed range: 30 - 3000
gps_rescue_throttle_p = 150
Allowed range: 0 - 500
gps_rescue_throttle_i = 20
gps_rescue_throttle_d = 50
gps_rescue_velocity_p = 80
gps_rescue_velocity_i = 20
gps_rescue_velocity_d = 15
gps_rescue_yaw_p = 40
gps_rescue_throttle_min = 1100
Allowed range: 1000 - 2000
gps_rescue_throttle_max = 1600
gps_rescue_ascend_rate = 500
Allowed range: 100 - 2500
gps_rescue_descend_rate = 150
gps_rescue_throttle_hover = 1280
gps_rescue_sanity_checks = RESCUE_SANITY_ON
Allowed values: RESCUE_SANITY_OFF, RESCUE_SANITY_ON, RESCUE_SANITY_FS_ONLY
gps_rescue_min_sats = 8
Allowed range: 5 - 50
gps_rescue_min_dth = 100
Allowed range: 50 - 1000
gps_rescue_allow_arming_without_fix = OFF
gps_rescue_alt_mode = MAX_ALT
Allowed values: MAX_ALT, FIXED_ALT, CURRENT_ALT
gps_rescue_use_mag = ON
deadband = 0
yaw_deadband = 0
yaw_control_reversed = OFF
pid_process_denom = 2
Allowed range: 1 - 16
Default value: 4
runaway_takeoff_prevention = ON
runaway_takeoff_deactivate_delay = 500
Allowed range: 100 - 1000
runaway_takeoff_deactivate_throttle_percent = 20
profile_name = -
profile 0
dyn_lpf_dterm_min_hz = 70
profile 0
dyn_lpf_dterm_max_hz = 170
profile 0
dterm_lowpass_type = PT1
profile 0
dterm_lowpass_hz = 150
profile 0
dterm_lowpass2_type = PT1
profile 0
dterm_lowpass2_hz = 150
profile 0
dterm_notch_hz = 0
profile 0
dterm_notch_cutoff = 0
profile 0
vbat_pid_gain = OFF
profile 0
pid_at_min_throttle = ON
profile 0
anti_gravity_mode = SMOOTH
profile 0
Allowed values: SMOOTH, STEP
anti_gravity_threshold = 250
profile 0
Allowed range: 20 - 1000
anti_gravity_gain = 5000
profile 0
Allowed range: 1000 - 30000
feedforward_transition = 0
profile 0
acc_limit_yaw = 0
profile 0
acc_limit = 0
profile 0
crash_dthreshold = 50
profile 0
Allowed range: 10 - 2000
crash_gthreshold = 400
profile 0
crash_setpoint_threshold = 350
profile 0
Allowed range: 50 - 2000
crash_time = 500
profile 0
Allowed range: 100 - 5000
crash_delay = 0
profile 0
crash_recovery_angle = 10
profile 0
Allowed range: 5 - 30
crash_recovery_rate = 100
profile 0
Allowed range: 50 - 255
crash_limit_yaw = 200
profile 0
crash_recovery = OFF
profile 0
Allowed values: OFF, ON, BEEP, DISARM
iterm_rotation = OFF
profile 0
iterm_relax = RP
profile 0
Allowed values: OFF, RP, RPY, RP_INC, RPY_INC
iterm_relax_type = SETPOINT
profile 0
Allowed values: GYRO, SETPOINT
iterm_relax_cutoff = 20
profile 0
iterm_windup = 100
profile 0
Allowed range: 30 - 100
iterm_limit = 400
profile 0
pidsum_limit = 500
profile 0
pidsum_limit_yaw = 400
profile 0
yaw_lowpass_hz = 0
profile 0
throttle_boost = 5
profile 0
throttle_boost_cutoff = 15
profile 0
acro_trainer_angle_limit = 20
profile 0
Allowed range: 10 - 80
acro_trainer_lookahead_ms = 50
profile 0
acro_trainer_debug_axis = ROLL
profile 0
acro_trainer_gain = 75
profile 0
Allowed range: 25 - 255
p_pitch = 46
profile 0
i_pitch = 90
profile 0
d_pitch = 38
profile 0
f_pitch = 95
profile 0
p_roll = 42
profile 0
i_roll = 85
profile 0
d_roll = 35
profile 0
f_roll = 90
profile 0
p_yaw = 30
profile 0
i_yaw = 90
profile 0
d_yaw = 0
profile 0
f_yaw = 90
profile 0
angle_level_strength = 50
profile 0
horizon_level_strength = 50
profile 0
horizon_transition = 75
profile 0
level_limit = 55
profile 0
Allowed range: 10 - 90
horizon_tilt_effect = 75
profile 0
horizon_tilt_expert_mode = OFF
profile 0
abs_control_gain = 0
profile 0
abs_control_limit = 90
profile 0
Allowed range: 10 - 255
abs_control_error_limit = 20
profile 0
Allowed range: 1 - 45
abs_control_cutoff = 11
profile 0
use_integrated_yaw = OFF
profile 0
integrated_yaw_relax = 200
profile 0
d_min_roll = 20
profile 0
d_min_pitch = 22
profile 0
d_min_yaw = 0
profile 0
d_min_boost_gain = 27
profile 0
d_min_advance = 20
profile 0
motor_output_limit = 100
profile 0
auto_profile_cell_count = 0
profile 0
Allowed range: -1 - 8
launch_control_mode = NORMAL
profile 0
Allowed values: NORMAL, PITCHONLY, FULL
launch_trigger_allow_reset = ON
profile 0
launch_trigger_throttle_percent = 20
profile 0
launch_angle_limit = 0
profile 0
Allowed range: 0 - 80
launch_control_gain = 40
profile 0
thrust_linear = 0
transient_throttle_limit = 0
ff_interpolate_sp = AVERAGED
profile 0
Allowed values: OFF, ON, AVERAGED
ff_spike_limit = 60
profile 0
ff_max_rate_limit = 100
profile 0
ff_boost = 15
profile 0
idle_min_rpm = 0
profile 0
idle_adjustment_speed = 50
profile 0
Allowed range: 25 - 200
idle_p = 50
profile 0
idle_pid_limit = 200
profile 0
idle_max_increase = 150
profile 0
tlm_inverted = OFF
tlm_halfduplex = ON
frsky_default_lat = 0
Allowed range: -9000 - 9000
frsky_default_long = 0
frsky_gps_format = 0
frsky_unit = IMPERIAL
Allowed values: IMPERIAL, METRIC
frsky_vfas_precision = 0
hott_alarm_int = 5
Allowed range: 0 - 120
pid_in_tlm = OFF
report_cell_voltage = OFF
ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0
Array length: 15
mavlink_mah_as_heading_divisor = 0
Allowed range: 0 - 30000
telemetry_disabled_voltage = OFF
telemetry_disabled_current = OFF
telemetry_disabled_fuel = OFF
telemetry_disabled_mode = OFF
telemetry_disabled_acc_x = OFF
telemetry_disabled_acc_y = OFF
telemetry_disabled_acc_z = OFF
telemetry_disabled_pitch = OFF
telemetry_disabled_roll = OFF
telemetry_disabled_heading = OFF
telemetry_disabled_altitude = OFF
telemetry_disabled_vario = OFF
telemetry_disabled_lat_long = OFF
telemetry_disabled_ground_speed = OFF
telemetry_disabled_distance = OFF
telemetry_disabled_esc_current = ON
telemetry_disabled_esc_voltage = ON
telemetry_disabled_esc_rpm = ON
telemetry_disabled_esc_temperature = ON
telemetry_disabled_temperature = OFF
ledstrip_visual_beeper = OFF
ledstrip_visual_beeper_color = WHITE
Allowed values: BLACK, WHITE, RED, ORANGE, YELLOW, LIME_GREEN, GREEN, MINT_GREEN, CYAN, LIGHT_BLUE, BLUE, DARK_VIOLET, MAGENTA, DEEP_PINK
ledstrip_grb_rgb = GRB
Allowed values: GRB, RGB
ledstrip_profile = STATUS
Allowed values: RACE, BEACON, STATUS
ledstrip_race_color = ORANGE
ledstrip_beacon_color = WHITE
ledstrip_beacon_period_ms = 500
Allowed range: 50 - 10000
ledstrip_beacon_percent = 50
ledstrip_beacon_armed_only = OFF
sdcard_detect_inverted = OFF
sdcard_mode = OFF
Allowed values: OFF, SPI, SDIO
sdcard_dma = OFF
sdcard_spi_bus = 0
osd_units = METRIC
osd_warn_arming_disable = ON
osd_warn_batt_not_full = ON
osd_warn_batt_warning = ON
osd_warn_batt_critical = ON
osd_warn_visual_beeper = ON
osd_warn_crash_flip = ON
osd_warn_esc_fail = ON
osd_warn_core_temp = ON
osd_warn_rc_smoothing = ON
osd_warn_fail_safe = ON
osd_warn_launch_control = ON
osd_warn_no_gps_rescue = ON
osd_warn_gps_rescue_disabled = ON
osd_warn_rssi = OFF
osd_warn_link_quality = OFF
osd_rssi_alarm = 20
osd_link_quality_alarm = 80
osd_rssi_dbm_alarm = 60
Allowed range: 0 - 130
osd_cap_alarm = 2200
osd_alt_alarm = 100
Allowed range: 0 - 10000
osd_esc_temp_alarm = -128
Allowed range: -128 - 127
osd_esc_rpm_alarm = -1
Allowed range: -1 - 32767
osd_esc_current_alarm = -1
osd_core_temp_alarm = 70
osd_ah_max_pit = 20
osd_ah_max_rol = 40
osd_ah_invert = OFF
osd_tim1 = 2560
osd_tim2 = 2561
osd_vbat_pos = 234
Allowed range: 0 - 15359
osd_rssi_pos = 234
osd_link_quality_pos = 234
osd_rssi_dbm_pos = 234
osd_tim_1_pos = 234
osd_tim_2_pos = 234
osd_remaining_time_estimate_pos = 234
osd_flymode_pos = 234
osd_anti_gravity_pos = 234
osd_g_force_pos = 234
osd_throttle_pos = 234
osd_vtx_channel_pos = 234
osd_crosshairs_pos = 205
osd_ah_sbar_pos = 206
osd_ah_pos = 78
osd_current_pos = 234
osd_mah_drawn_pos = 234
osd_motor_diag_pos = 234
osd_craft_name_pos = 234
osd_display_name_pos = 234
osd_gps_speed_pos = 234
osd_gps_lon_pos = 234
osd_gps_lat_pos = 234
osd_gps_sats_pos = 234
osd_home_dir_pos = 234
osd_home_dist_pos = 234
osd_flight_dist_pos = 234
osd_compass_bar_pos = 234
osd_altitude_pos = 234
osd_pid_roll_pos = 234
osd_pid_pitch_pos = 234
osd_pid_yaw_pos = 234
osd_debug_pos = 234
osd_power_pos = 234
osd_pidrate_profile_pos = 234
osd_warnings_pos = 14665
osd_avg_cell_voltage_pos = 234
osd_pit_ang_pos = 234
osd_rol_ang_pos = 234
osd_battery_usage_pos = 234
osd_disarmed_pos = 234
osd_nheading_pos = 234
osd_nvario_pos = 234
osd_esc_tmp_pos = 234
osd_esc_rpm_pos = 234
osd_esc_rpm_freq_pos = 234
osd_rtc_date_time_pos = 234
osd_adjustment_range_pos = 234
osd_flip_arrow_pos = 234
osd_core_temp_pos = 234
osd_log_status_pos = 234
osd_stick_overlay_left_pos = 234
osd_stick_overlay_right_pos = 234
osd_stick_overlay_radio_mode = 2
osd_rate_profile_name_pos = 234
osd_pid_profile_name_pos = 234
osd_profile_name_pos = 234
osd_stat_rtc_date_time = OFF
osd_stat_tim_1 = OFF
osd_stat_tim_2 = ON
osd_stat_max_spd = ON
osd_stat_max_dist = OFF
osd_stat_min_batt = ON
osd_stat_endbatt = OFF
osd_stat_battery = OFF
osd_stat_min_rssi = ON
osd_stat_max_curr = ON
osd_stat_used_mah = ON
osd_stat_max_alt = OFF
osd_stat_bbox = ON
osd_stat_bb_no = ON
osd_stat_max_g_force = OFF
osd_stat_max_esc_temp = OFF
osd_stat_max_esc_rpm = OFF
osd_stat_min_link_quality = OFF
osd_stat_flight_dist = OFF
osd_stat_max_fft = OFF
osd_stat_total_flights = OFF
osd_stat_total_time = OFF
osd_stat_total_dist = OFF
osd_stat_min_rssi_dbm = OFF
osd_profile = 1
osd_profile_1_name = -
osd_profile_2_name = -
osd_profile_3_name = -
osd_gps_sats_show_hdop = OFF
system_hse_mhz = 8
task_statistics = ON
debug_mode = NONE
Allowed values: NONE, CYCLETIME, BATTERY, GYRO_FILTERED, ACCELEROMETER, PIDLOOP, GYRO_SCALED, RC_INTERPOLATION, ANGLERATE, ESC_SENSOR, SCHEDULER, STACK, ESC_SENSOR_RPM, ESC_SENSOR_TMP, ALTITUDE, FFT, FFT_TIME, FFT_FREQ, RX_FRSKY_SPI, RX_SFHSS_SPI, GYRO_RAW, DUAL_GYRO_RAW, DUAL_GYRO_DIFF, MAX7456_SIGNAL, MAX7456_SPICLOCK, SBUS, FPORT, RANGEFINDER, RANGEFINDER_QUALITY, LIDAR_TF, ADC_INTERNAL, RUNAWAY_TAKEOFF, SDIO, CURRENT_SENSOR, USB, SMARTAUDIO, RTH, ITERM_RELAX, ACRO_TRAINER, RC_SMOOTHING, RX_SIGNAL_LOSS, RC_SMOOTHING_RATE, ANTI_GRAVITY, DYN_LPF, RX_SPEKTRUM_SPI, DSHOT_RPM_TELEMETRY, RPM_FILTER, D_MIN, AC_CORRECTION, AC_ERROR, DUAL_GYRO_SCALED, DSHOT_RPM_ERRORS, CRSF_LINK_STATISTICS_UPLINK, CRSF_LINK_STATISTICS_PWR, CRSF_LINK_STATISTICS_DOWN, BARO, GPS_RESCUE_THROTTLE_PID, DYN_IDLE, FF_LIMIT, FF_INTERPOLATED
rate_6pos_switch = OFF
cpu_overclock = OFF
Allowed values: OFF, 108MHZ, 120MHZ
pwr_on_arm_grace = 5
scheduler_optimize_rate = AUTO
vtx_band = 0
vtx_channel = 0
vtx_power = 0
Allowed range: 0 - 7
vtx_low_power_disarm = OFF
Allowed values: OFF, ON, UNTIL_FIRST_ARM
vtx_freq = 0
Allowed range: 0 - 5999
vtx_pit_mode_freq = 0
vtx_halfduplex = ON
vtx_spi_bus = 0
vcd_video_system = AUTO
Allowed values: AUTO, PAL, NTSC
vcd_h_offset = 0
Allowed range: -32 - 31
vcd_v_offset = 0
Allowed range: -15 - 16
max7456_clock = DEFAULT
Allowed values: HALF, DEFAULT, FULL
max7456_spi_bus = 2
max7456_preinit_opu = OFF
displayport_msp_col_adjust = 0
Allowed range: -6 - 0
displayport_msp_row_adjust = 0
Allowed range: -3 - 0
displayport_max7456_col_adjust = 0
displayport_max7456_row_adjust = 0
displayport_max7456_inv = OFF
displayport_max7456_blk = 0
displayport_max7456_wht = 2
esc_sensor_halfduplex = OFF
esc_sensor_current_offset = 0
frsky_spi_autobind = OFF
frsky_spi_tx_id = 0,0
Array length: 2
frsky_spi_offset = 0
Allowed range: -127 - 127
frsky_spi_bind_hop_data = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Array length: 50
frsky_x_rx_num = 0
frsky_spi_a1_source = VBAT
Allowed values: VBAT, EXTADC, CONST
cc2500_spi_chip_detect = ON
led_inversion = 0
dashboard_i2c_bus = 1
dashboard_i2c_addr = 60
Allowed range: 8 - 119
camera_control_mode = HARDWARE_PWM
Allowed values: HARDWARE_PWM, SOFTWARE_PWM, DAC
camera_control_ref_voltage = 330
Allowed range: 200 - 400
camera_control_key_delay = 180
camera_control_internal_resistance = 470
Allowed range: 10 - 1000
camera_control_button_resistance = 450,270,150,68,0
Array length: 5
camera_control_inverted = OFF
rangefinder_hardware = NONE
Allowed values: NONE, HCSR04, TFMINI, TF02
pinio_config = 1,1,1,1
Array length: 4
pinio_box = 255,255,255,255
Array length: 4
usb_hid_cdc = OFF
usb_msc_pin_pullup = ON
flash_spi_bus = 0
rcdevice_init_dev_attempts = 6
rcdevice_init_dev_attempt_interval = 1000
Allowed range: 0 - 5000
rcdevice_protocol_version = 0
rcdevice_feature = 0
Allowed range: 0 - 65535
gyro_1_bustype = SPI
gyro_1_spibus = 1
gyro_1_i2cBus = 0
gyro_1_i2c_address = 0
gyro_1_sensor_align = CW180
Default value: CW0
gyro_1_align_roll = 0
gyro_1_align_pitch = 0
gyro_1_align_yaw = 1800
Default value: 0
gyro_2_bustype = SPI
gyro_2_spibus = 0
gyro_2_i2cBus = 0
gyro_2_i2c_address = 0
gyro_2_sensor_align = CW0
gyro_2_align_roll = 0
gyro_2_align_pitch = 0
gyro_2_align_yaw = 0
i2c1_pullup = OFF
i2c1_overclock = ON
i2c2_pullup = OFF
i2c2_overclock = ON
i2c3_pullup = OFF
i2c3_overclock = ON
mco2_on_pc9 = OFF
timezone_offset_minutes = 0
Allowed range: -780 - 780
gyro_rpm_notch_harmonics = 3
gyro_rpm_notch_q = 500
Allowed range: 1 - 3000
gyro_rpm_notch_min = 100
dterm_rpm_notch_harmonics = 0
dterm_rpm_notch_q = 500
dterm_rpm_notch_min = 100
rpm_notch_lpf = 150
flysky_spi_tx_id = 0
Allowed range: 0 - 4294967295
flysky_spi_rf_channels = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Array length: 16
stats = OFF
stats_total_flights = 0
stats_total_time_s = 0
stats_total_dist_m = 0
name = WhoopLess
Default value: -
display_name = -
position_alt_source = DEFAULT
Allowed values: DEFAULT, BARO_ONLY, GPS_ONLY
Since I can find nothing to say if and what sensors the GepRC board offers I can only suggest that if SBUS is working then you know the wire is working UNLESS you hooked up the RX SBUS pin instead of the RX Smart Port pin or something (doubt that since FPort FW should only allow SmartPort pin to work, but I don't KNOW for sure). I would try 2 things, going back to an earlier RX FPort firmware and test, or reflashing to SBUS firmware and temporarily wiring the SBUS and Smart Port wires to see if any other sensors could be found (maybe remove the TBS Smart Audio wire temporarily from UART1). You are searching for sensors when the quad is battery powered and ready for flight? The other thing to try is to arm and leave idling on the ground and search again, some FC's need to be armed to have sensors available.
Got the replacement Diamond VTX/DVR today and have the same problem, no video in the goggles.
Rechecked everything and all seems correct. I tried reversing the video in/out wires going to the FC and then I got "Full Battery" showing in the goggles but still no picture. I removed the video in/out wires going to the FC from the VTX and tied them together and I have video.
At this point I am giving up on getting any OSD display or telemery and just slapped it back together. I will do the same as I do for the whoops and set a timer on my QX7 to countdown my battery time.
For now I am done building and will stick with BNF quads. I don't mind some tinkering but it keeps turning into lots of troubleshooting and not flying.
Hers a vid of its maiden flight. Nothing special just wanted to see how it flies. I didn't really push it and flew in Angle mode. It is faster than my whoops and was running a 3s pack. I did forget I wasn't in Acro once and try to do a loop...
peek.shwd
