Battery brand or suggestions?!
My favorite is Pulse (come to find out, it is actually owned by same company as Tattoo and Gens Ace). But unlike Tattoo, they are bright neon green. I like that since they are high visibility for recovery.
Reactions: broncosdad1317
You can fly a 2200 if you want but it will be heavy and fly like the brick it has attached to it. Most people fly 1300 on 5" quads. Just land and switch batteries. Your brain will need a rest after 3 or 4 minutes anyways.
Word sounds good. So does the higher the mah mean more power? Or just discharge rate so higher the mah means it lasts longer than a 1300
Well, it is sort if both in a way...
To find rated output current for a battery...
Take the capacity in Ah (mAh/1000)
Multiply that by the C rating
This gives you rated current output in amps.
So a 1500mAh 100C battery is rated for 150 Amps. (1500/1000*100)
A 1300mAh 100C battery is rated for 130 Amps. (1300/1000*100)
Donrabeja
