BetaFPV 65s Lite
acro69
I have a betafpv 65s lite whoop and I’ve noticed that when I fly in “level” mode, it tends to pitch forward and roll left without me doing anything to my pitch/roll stick. I’m also trying to connect it on betaflight so I can recalibrate the gyro but it won’t connect for some reason and I’ve tried using several cables to connect the whoop to betaflight. Let me know what else I can do. Thanks!
  • Sad
Have you ever successfully connected your PC to a quad? It may be that you haven't downloaded or installed the 2 driver packages you need? Don't use Zadig, but the other 2 are mandatory.
I have connected my Eachine Tyro79s and it worked fine. I used the same cable on my whoop that I used my other quad but it doesn’t want to connect. Where can I find those two drivers?
If you can still connect the Tyro79 then the drivers are fine, but there is a link to them on the startup page of betaflight configurator, CP210X and STM. Does the tyro still connect?
@acro69, I may have made a mistake, I think I remember someone else saying that the 65s was a Silverware load, if so, no connecting with PC as far as I know, you need to use the OSD and the TX to mess with it. Sorry, I don't know anything about Silverware but some others here do so hopefully one of them will be able to help.
Reactions: acro69
No worries! I just saw a youtube video that the 65s is silverware. Ill just try to mess around with the settings on the OSD.
buck
