This is a design and 3D print work in progress…
I’ll be carrying the Avata in an over-the-shoulder soft case with several dividers for the drone, goggles, controller, etc. and I don’t want the batteries to get strewn around. There will be five batteries in total, one in the drone and the other four in this case.
In whatever case I’m using for any drone, I keep the charged batteries heads up and then put depleted batteries in upside down. This makes it easy to see how many batteries are available for use.
With the rubber piece that sticks out from the battery, I needed an indent in the base to keep that rubber below the inside bottom portion.
I may figure out an elastic strap to put across the top of the case.
Comments and suggestions are welcome!
