Digging these new cyclone props!
Thanks for info… you added the prop mounts too correct?
Am I seeing rear vertical winglets (rudder)… just for fun or do you notice any improvement at speed? What speed do you feel improvement begins?
What are the real-world advantages to non-DJI props?
Reactions: harleydude
I'm not using 3rd Party props... yet... not graduated to Acrobat.
From what I understand if doing acrobatic mode aggressively, 1) the DJI props are not considered to be mounted "firmly" enough to insure not loosing a prop. 2) Non-DJI requires 3rd Party Mount that is screwed on to motor & uses standard Center Prop Post. 3) Size, pitch and stiffness are tunable with different props. You can slightly increase / decrease size and pitch, and you normally gain a stiffer prop with 3rd party for improved sensitivity or agility.
Reactions: okw
Can I just ask about the winglets at the back. Purpose, advantage. They also look really cool.
Reactions: BigAl07
viktor.rybk
