ESC dilemma. What ampere rating to choose?
Rax
For T-motor F60 Pro III 2207 2700kv motors to be use in racing, what ESC rating would you recommend for 4S? Most advise I get are mostly in the 35 amps range like the Aikon AK32 and Tekko32. But based on the motor bench test as indicated on there website, motor draws as high as 53.52A on 100% throttle and at around 29.48A on 75% using 5149 triblade. The 35A rated ESCs are capable of handling 45A burst current for 10 seconds. Question is will it be able to withstand current reaching 50+A? These ESCs are rated 6S by the way. Need your expert advise.
