Frsky XM+
Tonell
Hello guys,
I have some issues with my receiver. I tried to bind the receiver to my remote controller (Frsky X9 Lite S) but without success. I have updated the receiver through remote controler. I found some video on youtube. The led is green now but sometimes is flapping from green to red. My controler is not working, I have check in betaflight. I need some advice for this.
Also I have use kakute f7 v1.5 flight controller. And I put the cables on : GND, 5V and SBUS on R6. It is correct how I put the cables?
Thanks a lot!
The XM+ has an issue where if the TX is too close to the RX then it will lose connection and the red RX light will be lit. It is fine to put the SBUS on any completely unused UART/port on an F7 board, as long as it is set correctly in BF Ports and Config tabs.
viorel007
