HELP!!!!!
Keep the gyro and PID refresh rates low, that is an old f1 processor on that fc.
After trying for several hours I was unsuccessful trying to upload the new system it says that I needed to press the Boost button but I don't have one thanks again for all your help I will try to figure it out or buy a new CC3D board or if you recommend a better one that would be great.
Hi Calihulk, im new to fpv drones too buy had similar experience even with my brand new wizard. Turned out to be the failsafe on my transmitter, disabled that and everything was fine. The quad has its own failsafe so the transmitter one wasnt necessary anyway.
If you can work out which flight controller you are using it will help. Why not install the betaflight GUI (if you dont know how look it up on youtube) plug your quad in and see if it connects. If not, maybe try others. One you have the right one you'll be able to see if you're arming the quad. If it doesn't arm try going though a setup guide on you tube.
Texecdeza
