Led lights meaning
Droner
Hi, can someone explain the meaning of the green and red led lights on hobbywing flight controller.
Usually 1 LED is on to say that 5 Volts is present to the FC, that is likely your Green one, and the other which is usually Red will flash to say that the CPU is in a running state. It really doesn't matter much and is not a "troubleshooting" tool. You will learn more about what is going on if you do a "status" command on the CLI of the Betaflight Configurator.
Soso
