Loss of Control After Avata Upgrade
Hello, everyone. I'm hoping for some input after my crash yesterday. I did the AxisFlying 3.5 frame and motor upgrade on the avata, and took it out yesterday for the first test flights.
First one went fine. 10 minutes of slow cruising. Stayed in normal mode, low, and close to home.
Second flight I sent it up to look around at 29 stories. Got up no problem, but felt like I was getting buffeted by the wind more than usual, which was unexpected with the heavier weight and bigger props. Came down to find calmer air, and as I got lined up for a straight run above a street, all hell broke loose.
You can see as I line up with the brick street and begin descending, the drone starts oscillating from side to side. My first move was to hit the brakes and throw it into hover. You can see where it attempts but then immediately disengages.
My second move was to cut all throttle and get down as fast as possible before it lost all control. I was afraid it was going to flip over on it's back. As I cut power, I also tried to nudge it left a little too try for a parking lot landing instead of the middle of a street.
None of that worked. It kept rocking wildly and lost altitude slowly. It did get to the left a little, but crash landed on a parking garage roof. Battery went from about 59 percent to zero upon landing, and I think I had an ESC error in the googles but I was more focused on getting it down than reading the HUD.
Opened everything back up today and double checked all my soldering. No bridges and nothing loose, as far as I can tell, but I'm hesitant to put it together and get it back up in the air without some opinions on what the problem might be. Hoping for some input and direction. Thanks in advance.
