Motion controller yaw not working
Przemo-c
I'm on my second motion controller.
The issue I'm having is that yaw motion on the controller is not reflected in drone motion. I can pitch and roll the controller to yaw/do coordinated turns. But doing yaw motion on the controller/rotating my body does nothing.
I tried recalibrating compas and imu.
I don't have the option MC horiz rotation control on motion controller menu in the goggles.
Tried on v01.001.0000 and v01.002.0000 motion controller firmware version.
Is there a way to enable yaw on controller yaw?
There is a setting to enable this. Look under the motion controller options in the goggles .
I know. But as I've stated I don't have that option In motion controller menu
I only have disabling of that controller overlay and instruction videos
You do. Go to settings, control, motion controller. There are 3 switches. The bottom one says something like MC Enable horizontal movement control. Switch this on, and you have horizontal movement control, i. e . Yaw
As I've stated previously... twice ... there's no such option in the menu. I'm attaching thru the lense photo of said menu so i won't have to state it again. That's my issue... I don't have the option to enable it and I've writen that in the first post.
Could you check what firmware version you have on your goggles for the motion controller, drone, goggles?
It might not be MC firmware, maybe said option was introduced in one of the newer Googles FW, didn't you stay on the older one?
I will check mine in the evening and post what I see along MC and Googles FW.
I have flashed in DIY mode to 0606 version which should equate to 0020 on the DJI drone boot side.
I'd love to see versions of firmware for drone , controller and goggles that someone that has yaw working on motion controller.
Checked, drones and goggles on 01020020. Controller is 01020000.
You seem to be missing the bottom option, see pics. Suggest you contact dji support and ask why.
Thanks, asked them no response, tried re running tutorial but that didn't change anything.i have 010010606 in the goggles which should be the same as 010020020 for the DJI drone boot side but will try flashing on the fpv drone side. My drone is on 010020000 for FCC hack buy will try 01.002.0020 on the drone as well. Thanks
Eleveniseven
