Hi All
thought i would share a fix to an issue i had with a new build it may help some out.
i built and iflight XL5 low rider on Saturday and had its maiden yesterday an noticed i was getting a lot of noise and oscillation at mid throttle. i checked everything and ended up rebuilding it with no fix.
Then something clicked in my head (i don't know why) but decided to check the zip ties on the arms and it was pinching the motor wires too tight on motor one, moved the zip tie and problem solved.
so check the easy things first before you end up rebuilding it
